Which model DELL supply are you using. I have a 100Amp DELL, but it does not have a load share pin.
- 399
https://www.core4solutions.com/dell-kd175-poweredge-6800-1570w-power-supply.html
There is a kd175 version and a jd200. I have the kd175 and it runs at 12 to 12.5 volts. Any higher and the over voltage protection will trip. I believe the ovp is easier to defeat on the jd200.
