60 pep is about all I feel comfortable with.
You can trust Laird and Larsen's power specs. I'd be comfortable running 200 ish watts. The mount looks capable, as well.
The Lasen coil and stinger combination I mention earlier, up the thread, would be perfect in this sition. Especially, since the hole is popped and the NMO is mounted. Even the Larsen NMO-27 has marginal performance. The base and stinger I mention, would give more gain, and possibly, a smidgen more bandwidth.
Before doing that, maybe try a longer stinger and start tuning all over again.
Nope, that's something I don't have and here in the part of podunk Texas I'm at I don't think anyone around here has one either. I'm using a handheld radio with an so239 adapter and small workman swr/power meter to set swr. I've checked the meter on the bench with the mfj meter into a dummy load and reads right on. That's the best I've got. It would be nice to know where the antenna is resonant.U have access to an antenna analyzer?
Did u ever figure out what happened to your antenna?
