lords
500 watt MOSFET amp at 13 volts is not to costly to build
I am working on a small unit right now that has 16 MOSFETS for about 500-600 watts ..$1.99 a Mosfet ain't bad
but your talking about 1-10 watt input and 75-100 amps full load...
still ain't bad for a cheap amp...and if its a base amp add the $$ for the transformer and the bridge...don't know the cheapest prices on these yet butI am working on it..this way you can take it mobile to with just un-pluging it from the base setup...it's about half done now but I would like to see rfpowerman back on track with this..with the MOSFETS....and for each setting a built in LP filter
hope your getting better....
Your Friend on this end,
Mark
Mark
