Homer, did you ever notice or try and check to see if your A/P mounted over your beam had some affect on the match, if you could tell? I can't remember.
Is the A/P noted here the one you made?
The AP in the above post and lower photo is the one I made. It has a flat SWR across the CB 40.
2.0:1 ------- 29.485
1.4:1 ------- 26.000 I will have to put the analyzer on it to get the 2.0:1 bandwidth. This is the radio/SWR meter reading.
It is 9.5' above the 4 el Yagi. Yagi also has a flat SWR. Seem s to be no negative issues where it is.
