I like the idea of building the Moxon. An idea popped into my head: would it be possible to stack a pair of Moxon? Why build one when you can build two just as easy?
Here's what I have been using @ 20 feet . It covers 27.385 and targets 28.300KC9Q. Very helpful . I put my Moxon up today. Used the measurements for 10 meters. It seems to have the lowest set at 29.2 MHz. I’m going to adjust it out tomorrow as far as I can safely.Thanks
I used your measurements. Strangely the swr is 2 to 4 on 11 meters, lower on 10 meters. I’m going to try tuning with wires . Another problem I can’t help is the power lines are 23 feet away and seem to lower receive. I’m gonna have to raise it from 20’ to be able to use it pointing south.Here's what I have been using @ 20 feet . It covers 27.385 and targets 28.300
All numbers in inches
A =156
B = 21
C = 6.75
D = 29.75
E = 57.5
I just put a 915 in my little shack and I thought my SWR meter broke. I swapped the 915 in and out a few times I could not believe it helped that much.Donny, try adding a 1:1 balun (though you can still just tune using different measurements). I use a cheap mfj-915 isolator which seems to tame the SWR numbers.
Let me straighten this out.
1. when I built Moxon antennas I used the MoxGen application, a center frequency of 27.385, and I had to change the center freq from 27.385 to something higher to get an antenna that operated on center where i wanted it. MoxGen made both wire and tubing antennas lower down on the band than I wished.
2. when I posted the above two diagrams it was from an online calculator. I used a center frequency of 27.2 for the 11 meters dimensions and 28.4 for the 10 meters antenna. I know nothing of its accuracy.
3. I used 1/2" tubing for the metal antennas, and #14 wire for the wire antennas. I left the insulation on the wire antennas.
I believe the tubing antenna is more durable.
Here is the exact measurements of my Moxon I have up now. according to MFJ-259 it has a center frequency of 27.3.
Definitely needs a choke, you can get some strange results if you have a CMC problem
Guess that is why some report that the position of the coax is so important.
Finally it's a 2 el beam forward gain is about the same as any other 2 el. what makes it special is the coupling of the bent elements providing that bandwidth , match and F to B. I think the future of yagi antennas will be with critical coupled (bent) elements.
This is some of my observations based on making dozens of Yagi, quads, moxons, skyppers and quagis .
Would love to hear your real world experiences and results.
One thing I forgot to mention was the significance of the position the feed line needs to enter the driven element perpendicular to the element . Any other angle , I found affects the VSWR
My amp builder saw my wire Moxon I had up in the back yard at a stateside house I had and he put one up on my measurements and made it rotatable between horizontal and vertical, with a little higher reflect in the vertical plane , I suspect due to the tower , he worked locals very well also.
