MFJ Moxon
Not familiar with the Mosley. The 2000 and the 99 will be about the same performance wise and the 99 is cheaper. The Moxon is directional & horizontal pol so comparing it to the 99 & 2000 is a bit like comparing apples to oranges as they say.
That's my 2 cents worth...
Understood, considering the Moxon is directional. Thank You
Reactions: Dusty1USA
Well this whole thread has been exceptionally informative. Many thanks to all the commentors.
My Moxon is about to be built for 11 meters. Ain't this fun.
BTW, I put together a dipole inverted V for my first build a couple of weeks ago. Hung it in a tree about 26' to the center point with the legs at a 45 degree angle down from the horizontal plane. It seems to out talk and out hear the Tram 1498 on my roof.
Thanks guys, I have enjoyed the whole thread.
Reactions: Crawdad
Dusty,
Just curious, how have you calculated your Moxon and have you been able to model it?
7 3
  • @ Geoexplorer69:
  • @ Geoexplorer69:
