Well ... maybe if someone makes a receiver that will handle 20-22khz.
- 399
For anyone looking for a cheap Hi-Fi wideband multimode receiver,
I'm leaning towards getting an RTL-SDR and an LNA4HF (filter/amplifier) for under 70$ total shipped, but requires a computer/laptop to operate.
That gets you an easy 30 KHz receiver, with a pass filter to block out the high powered commercial FM Broadcast stations that commonly interfere and overload the cheaper software defined radio receivers front end. You can just a receiver anyway you like, squelch, AGC, width, filters, NB +more.
Though you could use almost any low noise amplifier and bandpass filter with an RTL-SDR (cheap); I just think the
LNA4HF looks promising. Without a filter the local fm stations cause overload issues, but the receiver has an extremely wide range tuning range 150 KHz to over 3 GHz (I think), with many modes, AM, FM, SSB, CW, and more.
The SDR# software is free, and many great plugins exist.
Just don't transmit right next to it, without first disconnecting the antenna or switching it out of circuit with a relay or something! (I do this to be safe, I don't know if the SDR will die from an up close or extremely strong signal)
I dummy load test CB's right next to the computer and watch the results in an "RF spectrum", it's too bad you can't sample a huge range like a spectrum analyzer can. But it's good for sampling transmitted audio, and looking for harmonics. (Leave the SDR antenna plugged in, and use a dummy load near the computer/SDR antenna.
Cheap Hi-Fi receiver, and an improvised "ghetto tech" style testing tool in one package!
I think Mike did a great job on the review even though he did not exceed 100% modulation, I wish he tested everything, including the asymmetry lol.
