I can barely work with 1/8 watt resistors my friend...I'm using this now:I think it would work, but if you don't mind sticking leads on a surface mount part, there is one with a closer voltage (9.65) rated at 1w
KDZVTFTR9.1B | Digi-Key Electronics
Order today, ships today. KDZVTFTR9.1B – Zener Diode 9.65 V 1 W ±6.04% Surface Mount PMDU from Rohm Semiconductor. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.com
maybe a little scrap of board cut from a spot with parallel traces that can accommodate both the part and leads.
