I am currently using a modified sirio pl5000 with a cut down 102" whip, you have to cut the whip to at least the same length as the stock whip, the bottom section has to be drilled out, I used a 13/64 bit for this and it is a tight fit, still and able to use both Allen screws as well. The 102" cut whip works well but is way heavier than the stock whip, I have my setup on top of a work van and there is no headliner, so I installed 6 5" magnets on the bottom side of the 6" magnet that's on the roof. It holds very well and has yet to be knocked down even at 70+ mph on the highway and hitting things. I did this as I was having issues with the stock tip getting bent, but you have to understand that my truck is 8ft9in at the top, which puts my antenna tip at 14ft2in., most people aren't running their antennas this tall. The cut 102" whip is much stiffer and heavier, but I am happy with the results of my setup. There is nothing wrong with the stock whip on the sirio pl5000 as long as you aren't going to be hitting a lot of hard objects, and I don't mean little branches, more like bridges, underpasses, large branches and so forth. IMO, the sirio is a better antenna than the wilson, I have used both and a k40 as well, and setup right, the sirio has better tx/rx range and is built better. JMO. Anyway, not sure what your plans are, but the sirio pl5000 and the 145 mag mount if you aren't planning on a hard mount, is going to be the best setup, IMO, that or a quad mag mount and predator 10k. And as far as coax, you can upgrade the coax from the factory (sirio). Like I said, check out DNJ radio and at least have a look at what they have, and they are good about replying to emails as well. Good luck and hope you get it all sorted. My vote is for the sirio pl5000 with the 145 mag mount. God bless.
