Looking for a good Magnetic mount CB antenna for Tahoe. Whats your thinking on K40 vs MaxRad 2700 NMO ? Nothing to expensive here for casual use with just a HOT Cobra 25, no heat.
555
555
The SIRIO 4000 or 5000 is a great antenna. Has a real broad band of operation and not real expensive. H&Y has them.Sirio 4000 or 5000 Performer. Drill hole in roof and put in a permanent fixed mount.
No way would I even consider drilling a hole in the roof. I was looking for opinion of a K40 or similar magnetic mount, that's all.
555
555
Why wouldn't you drill a hole in the roof of a Tahoe? A magmount will damage the paint a whole lot more, especially the coax that flaps about. You also have the issue of the coax getting crushed as well and the paint discolouring where the magmount sits.
Drill a hole, fit the antenna. When you sell the Tahoe fill the hole with a cheap GPS antenna.
