Yes.I really am not seeing any complaints about performance. Also are there any 10 Volt Cap's in this radio?
http://www.cbtricks.com/radios/president/jackson/graphics/president_jackson_pb-042_sch.pdf
02-09-2013, 09:10 AM
Robb
This message has been deleted by Robb.
I think this picture is worth a $1000!
Can there be ANY doubt at this point that it is an Original Jackson Export?
You decide . . .
It also appears that my main buddy Wayne cranked up the bias pots all of the way to the right.
Check your bias current if you bought a radio from Wayne !!!
The driver bias was set at 270mA (supposed to be 50mA) and the final bias was set at 0mA (supposed to be 80mA). I am putting in a new .22uf/50v cap and replacement MV1Y biasing diode and see if I can get a reading better than 25mA (again, it should adjust to 80mA) that I have been getting for the final. If I can't; then the final is toast. Wayne will be getting a call from my credit card company and eat a radio.
Also going to pull out TR26 and add a 1.5kohm resistor to the center leg and put it back in the radio. This will remove the compression from AM transmit WITHOUT taking out the AM Limiter altogether. The way it should be done - right. Yup yup . . .
So in the end what do we have here? Is is an N.O.S superstar or an old N.O.S. Jackson? From all of your experences with this radio so far I am convinced that their has been some doctoring of board numbers and components....But why?...To what end? Their seems that their was allot of effort involved to cover up things.
We all know why companys alter component #'s and things of that nature, but to go to this extreme has even got me thinking. False statements, outright lies, board # changes, Gross embellishments from sellers.
But nevertheless it is what it is. A rough turd that needs work. So what would it be after that? Is it something that would have a place on the shelf next to the original classic's....Maybe. we will have to see.
The mystery deepens. I myself would like to know above anything else what radio that this main board was meant for?
So you are saying that the correct bias cannot be set correctly as it sits without changing out those components? If the final is toast, perhaps it would be a good idea to R&R the final section BEFORE firing it up for the first time due to the corrosion? Unless it was done by the manufacturer checking if the unit worked.
I flagged this hacks posting on Craigslist.
Did you call this guy Robb?
