I have seen this antenna test results and would like to pass along the info to everyone.
This has been copied with permision....
... needed with the I10k to cut down on bleeding since 5/8 wave antennas are notorious for signal comming down the coax.
... so i'm convinced
And another thing I noticed about this so-called comparison... The counterpoise system of 1/4 wave radials found on most 5/8 (.64) antennas decouples the coax from the possibility of feedline radiation, or common-mode currents.
I tend to use a common-mode current choke in the coax as a final preventative measure, but it is, for the most part, unnecessary when using an antenna with a counterpoise.
This was recently proven at John's (WR-897) home. He had always had problems with his own TV receiving TVI when using his newer-version Astroplane (Top Hat) antenna. We built a .64 from parts and pieces, including an old Hy-Gain CLR-II hub, made a 5-radial counterpoise and now he has no TVI, and WITHOUT a current choke in line. He doesn't even bother the neighbors TV & Stereo equipment anymore.
I find this entire comparison 'incredible' in the strictest definition of the term. The only application where I can accept that it might slightly excel over a .64 would be in Sporadic E - high angle short skip conditions.
