where the jumper would go to make usa az cb you have them or you put a swich, you flip it from cb so you go to freeband mode hit scan button and go, it takes for ever, scan is SLOW. now EZ way #2 in free band mode pre set #1 to 27.695. with rig on pre set #1. hit scan button, and rig will scan, it's SLOW. key mic to stop when you want to stop, talk what ever. i scan most of the time by starting at my lowest pre set im scanning from and use the mic buttons to scan, it's MUCH faster, and you have better control. as a rule I run 27.385 lsb (pre set), 27.505 usb (pre set), 27.555 usb (pre set), and 28.405 usb (per set) , and last, 25.855 usb (pre set). and yes i do run 3 antenna's in the mobile, and run ts500, now but also run sweet 16 in the truck too, and I have 3, 350 amp alts. and I like to DX...
p.s when you call dave at yeticomnz just tell him what you want.....thats all. 73's
