It will do personal assessments to disqualify the forum members if they do not like your position.
Here I made another drawing not to like someone, but once I'd love to see even just one time, a semi-scientific explanation as to ask for a scientific explanation which only praise as evidence preach without more words and sayings of others, "he told me".
I see it. Phases canceled against each other.
Is very interesting, there I see all currents and phases.
Is as you say, half wave fed quarter wave. But at the bottom I see nothing collinear, if collinear, there would be no wave movement. A collinear antenna, ripples appear and disappear at the same point, as a dipole.
See that cone leaves a green color that is the variation of field AND PHASE CHANGE.
Therefore, the cone is in antiphase(yellow & blues colors) with the rest of the antenna.
In this picture, we see that the phases are perfectly changed inside and at the bottom of the cone, a part is blue, the other yellow, or that are not in phase
if they were on stage. the red color would be the left side and blue on the right, however are extrapolated, with an inverted phase of 180 degrees, so if there is emission is 180 degrees out of phase, which makes NEGATIVE
if so be collinear, and in phase, CST modeling both colors would be on the same side.
any scientific explanation for this?
