This time also indicates that CONE ALSO WORKS IN REVERSE IN PHASE WITH ANTENNA.
Is clearly visible ANTENNA THAT IS CANCELLING IN PHASE AUTO INVERTED.
The antenna also cancels itself, generating neutral fields between opposing currents.
The CST model antenna diplay this in slow motion in the following animation.
See that cone leaves a green color that is the variation of field AND PHASE CHANGE.
Therefore, the cone is in antiphase(yellow & blues colors) with the rest of the antenna.
In any case the emission of the cone gives loss to the antenna.
In this picture, we see that the phases are perfectly changed inside and at the bottom of the cone, a part is blue, the other yellow, or that are not in phase
if they were on stage. the red color would be the left side and blue on the right, however are extrapolated, with an inverted phase of 180 degrees, so if there is emission is 180 degrees out of phase, which makes NEGATIVE
