my up graded sigma will be close to 3/4wave with 108" radials Eddie, mainly to increase wind survival,
If it was me Bob, I too would 1st modify my S4 model with 107"-108" inch radials and use a 3./4 wavelength radiator. Get it to work right and then maybe make the radiator longer and see if the gamma is able to make a match and possibly get more gain. Then you can report to use if you still see increased gain at a distance...like you did with your Vector Hybrid.
is it safe to say that the 3/4wave version with the 107" radials when installed at the same tip height as the extended versions with either 90" or 107" radials gives the best performance at low angles ?
I have not done that comparison yet, but I will post it soon.
BTW, have I posted something about using Eznec's Average Gain Test and using the "gain correction factor" it also provides for models that get into trouble and need a fix like Steve and I have been doing recently...to make some models show AGT = 1 and get the match looking good at resonance too.
I found the 1st "old" Vector model that ever I did with taper and without taper. I checked the Free Space Average Gain on both, and the one with taper was off a bit showing a 0.83 db correction factor. The Real Earth model reported a gain of 5.13 dbi and was overstated due to the AG error reported. So, I did the math and got: 5.13 - .83 = 4.30 dbi.
I did the same for the model without taper. It had a perfect AG, so there was NO correction needed. However, the match was of at 1.453 SWR (not so bad) but off. This model reported a gain of 4.34 dbi.
Again this shows that taper does not report as bad a model as some folks report.
Then I took my most recent Vector model at 323" inches and it reports a perfect 1 AGT, and reports 1.048 SWR with a gain of 4.33 dbi.
With this I figure my older Vector models were fine, because this shows us the gain for these old model with/without taper vs. the more recent model all produce almost identical gain results at about 4.30-4.34 dbi.
me & Donald fell into the trap of seeing what we wanted to see because its not clear to the untrained eye what the cst image is showing, we don't have that problem with eznec,
So, all this time Eznec could have been reporting accurate gain results had Steve and I just made a Free Space model and used the error correction to fix the gain and made it clear what was going on.
Big difference would have been...asking folks to believe any gain results reported from a model with a bad match and maybe showing currents on the mast. In such cases they would be inclined to get the eye-candy factor...that is common in human perspectives on many things. Plus we all tend to believe what we believe...come hell or high water.
