Just getting back into CBing , after almost 50 years, since early '70s. Use to be just a mobile user with a Realistic TRC 448, 40 chl, and talked "skip" all over, from down in the Alamo City.
Now I'm using a mobile Galaxy DX959 as a base station with a Proton 99 antenna and a
Twinpoint B-100 SATURN 39" low profile base antenna. Both antennas are mounted aprox 28'-32' high.
I never really got into SSB back in the 70's before I was transferred overseas in the military. Now I am trying a little SSB. My concern is the difference in the noise level on LSB/USB vs AM. When using my PROTON 99, I am use to the regular type of noise while on AM, but when I switch to LSB or USB I get a loud "crackly" noise (almost like snap, crackle, pop). Almost like an engine/motor running; but nothing is running, and it is on all channels. Switch back to AM and it's just the regular channel static noise. But when I'm using my SATURN B-100, the noise is basically just the regular channel sound. I can hear a slight crackly noise, but very slight.
I'm wondering, if it might be from where I've run my RG58 cable thru the outside wall into my house. My cable goes thru the wall, about 2' from where the main elec power comes up from the ground and into to outside pwr box.
Any ideas?
Any ideas?
