It will not work!! GP kits, better coax nor magic beans will make it work.
You are getting very good advice here
Well nobody has told me I'm screwed just yet.
The A99 seems to work well on 20m according to many operators reports, perhaps you could install an A99 then simply add a 17' wire on the mounting bracket to create a 20m quasi-1/2 wave center fed...?
...and add your eight 2' radials on it for decoupling 10-11m.
Take a look at the Hustler 4 5, or 6 BTV series verticals. These can be ground mounted with or without radials and under $200.I just don't have the space to do that. fourstringburn, You play bass??
Good guess, I am a bass player and also a classically trained pianist who likes to talk on radios!
Only if you keep trying to use a cb ant..Well nobody has told me I'm screwed just yet.
Those hustlers can be roof top mounted.
Think man ! there is plenty of options.
You could use the imax as a mast for a inverted v surely you have someplace to tie off the ends to ,Roof gutter ,fence ,dog pen etc,.
Or how about a 1/4 wave ground plane. using wire ground planes.
Or a !/2 wave vertical dipole (sleeve dipole style) T2LT about 32ft long
Or a 5/8 Gain master style. ( thats 43 ft long though.)
Even if you scaled the imax up and added another 22ft of wire to the end and tied it off to whatever you can find in your yard , horizontal or sloping down, whatever, it would work better then what you have.
Honestly it's not about your budget. It's about your knowledge and ingenuity .
That is not what I said, what i did say is a GP kit on the antenna you first mentioned will not allow it to work on 20 meters betteraccording to w9cll the only groundplane kit i can use won't work
