First of all, let me say that anyone who is modding their CB
radios for extended bandwidth and loudness so they can
play music on-the-air are total f...ing IDIOTS.
Secondly ... there is so much bullshit and misinformation on this thread, that I can't believe.
Asymmetrical modulation , by definition, is distorted. If you
take a pure sine wave, and reduce the negative aspect, it
introduces distortion, pure and simple. Asymmetrical
modulation is used by AM broadcasters to make their signals
louder than their competitors. Rf, modulated to 125% on
positive peaks and limited to less than 100% on negative
peaks, will be 1.94db louder than one modulated
100%/100%. Almost twice as loud. BUT... 125% positive
peaks introduces a ton of even-order harmonics that MUST
to be filtered out in order to maintain a (somewhat)
distortion-free, natural-sounding output. Not to mention keeping the neighbors happy !!
Many people say that the NPC mod for CBs makes for a
more “natural-sounding” audio. This is not true. The human
voice is naturally asymmetrical, and putting it into a
“forced” asymmetrical environment with the NPC mod,
changes it beyond belief. AM broadcast stations spend tons
of money on audio processors that produce 125% positive
and less than 100% negative modulation peaks to meet FCC
regulations. In all honesty, can you believe that a simple
diode/resistor mod on a cb radio will produce the same
result ??? If you do ... WAKE UP ... you’re dreaming.
IMO, you’re better off using tried and true processing
techniques like audio compression, hard peak limiting, audio clipping, etc.,
to make your signal loud and clear.
200% positive/ 95% negative looks great on paper, but I'll bet the on-the -air sound has distortion +++. Besides, the unbiased 1N914 ( or equiv.) diodes used as AM detectors in most AM CB receivers can't even come close to handling 110% positive peaks, let alone 200% peaks. Sure, a transmitter can be modded to do a lot of things, but if Average Joe's receiver can't process the signal, what have you accomplished ???
CB radio is for VOICE COMMUNICATION. If you’re looking to
play like you’re a AM broadcast station, get a part 15
transmitter on Ebay and go for it. Just watch out for the
Federales !! But keep the music and other Bullshit off of the
Cb and freeband channels !!!!!!!
- 399
