I just noticed the antenna name, does that mean "Five channels of British Television?"
I guess you will have to ask M0GVZ that question.
. What is magical about a 43 foot antenna? Why not 54 feet? Or 47 feet?
The big difference between a 43 foot antenna and the 5BTV is that the 5BTV functions as a 1/4 wave whereas the 43 footer functions as a whatever wavelength with the attendant various and often useless for DX vertical angle elevations.
True, except matching it. The remote tuners have plenty of range and many people I have heard from using these antennas have had no problem matching up with a tuner except bands below 40 meters. This is where MFJ and DX engineering sell UNUN transformers to be put near the tuner to be able to match 80 and even 160 meters. Of course your efficiency is way down, but it will let you work the bands.Also the impedance of a 43 foot antenna will be all over the map and some bands may be hard to get a good match using a remote tuner.
As for traps radiating harmonics I never heard of that. the traps themselves do not radiate harmonics.
Also by not having a remote tuner at the base I don't have to worry too much about losing it due to a lightning strike.
Sounds like your antenna is working just fine.
So now I ask why a 25ft trapped vertical with lots of radials would be better, worse, or the same as a 43ft non-trapped vertical with lots of radials and a remote tuner at the antenna feedpoint?
1 antenna is almost twice as short and has losses with the traps. Also traps are known to radiate harmonics.
The other antenna is too short for the low bands and too tall for the higher bands and has losses in the tuner.
The Hustler is only a 1/4 wave at 30 meters whereas the 43ft is close to a 1/4 wave on 60 meters. As with ANY VERTICAL ANTENNA, The longer the antenna the better! I have seen commercial AM broadcast stations use shortened verticals with Cap-hats and my guess would be for antenna height restrictions for the particular location. Other than that, many are tall verticals at 1/2 or more wavelengths.
The Hustler has to use a resonator coil to get 80 meters.
Both antennas require lots of radials for each band.
It's trapped antennas, so is that similar to saying the traps themselves??? I meant it originally as the Hustler being a trapped antenna, these types of antenna " may" radiate harmonics.
I'll copy paste from the VE2AAY Canadian Amateur radio exam so maybe you can argue that their test is wrong if your implying that trapped antennas aren't known to radiate harmonics !
B-6-12-7
What is a disadvantage of using an antenna equipped with traps?
- A.
It is too sharply directional at lower frequencies- B.
It must be neutralized- C.
It can only be used for one band- D.
It may radiate harmonics more readily
That's the best argument not to use one because the cost of a legal limit remote tuner is around $800
To sum it up, both antennas will work. One Is really short for a vertical and uses traps that are lossy but can have a low SWR and good bandwidth but that doesn't mean efficiency is good because on some bands it could be like a leaking dummy load. Is this much different for me using a 4 ft mobile screwdriver antenna and logging over a 100 DX countries?
The other is a much taller vertical and uses no traps or coils but relies on a closely mounted remote tuner and UNUN for the lower bands. This is similar to the mobile Icom AH2 tuner/whip combo.The losses are in the tuner, not so much the vertical radiator since it's not being loaded up with coils and traps.
The Hustler will be a good enough temporary antenna for you until you get to put up your Yagis. Any antenna is better than no antenna! The 43 ft would still be good but for you the costs wouldn't be justified for a temporary antenna.
Got that right!Am I satisfied with this especially since it is temporary and seems to work quite well? YES and that is all that matters.
Cap hats on AM towers up here are VERY rare to find
some a little longer and some a little shorter but RARELY are they ever 1/2 wavelength especially on the low end of the band.
It depends on the type of tuner you use. I have a Yaesu auto tuner that is good but stumbles on some impedances. It's just another unnecessary expense for a temporary antenna installation.
The trap losses are not nearly as bad as some amateurs like to think. There is a lot of info out there that will attest to this. Y
Anyway this whole thread was about my installation and not about what COULD have been done if it was someone else. Are there better options? Yes a Steppir vertical would be GREAT but $$$$. Am I satisfied with this especially since it is temporary and seems to work quite well? YES and that is all that matters.
I don't honestly know. You asked this question on other threads too.
The number 43 comes from calculated lengths for random wire and center fed doublet antenna element lengths.
Essentially, when running a tuner to random length antennas generally one or more bands were presenting impedances that were out of range of the tuners ability to tune. Because of this, people started calculating the lengths that were not a multiple of any of the HF ham bands half wavelength, and with this information looked for the lengths that were the farthest away from these high impedance multiples. This was done to make it easier to tune all bands on said antennas. 43 feet is one of the lengths that is not a half wavelength multiple of the higher HF ham frequencies.
The DB
Here is a google map pic of one 50 miles north of me. This is a 5000 watt daytime AM broadcast station but cuts back to 200 watts at night. This antenna has a caphat and that's what got my attention when I saw it so I looked it up to get more info. If this one exists, there are sure to be others. I never said they are rare or common place, they just exist in some areas.
https://www.google.com/maps/@35.700...4!1sNqE_gVYc9hM12H3_KWlLYA!2e0!7i13312!8i6656
Here is the specs of our 50Kw station. Unless my math is wrong, at 770 KHz at 196 meters, that is a 1/2 wavelength LONG.
Elevation Info Site Elevation: 1524 meters
Height of Structure: 196 meters
Overall Height Above Ground: 196.6 meters
Overall Height Above Mean Sea Level: 1720.6 meters
http://fccinfo.com/CMDProASRLookup.php?tabSearchType=ASR+Search&sASR=1005235
Never denied that. But is your Yaesu a remote tuner? The 43 ft requires one not a shack tuner.
Any antenna mounted matching device is lossy, whether how much depends on the design. The 43ft has it's the majority of it's losses in the tuner.
You never addressed the Fact the when it comes to verticals, THE LONGER THE ANTENNA THE BETTER!
Exactly. I already mentioned that this debate is really carried over from another thread which to me seems you got offended because I said the OP should go with a shortened rotatable dipole AT HIS INSTALLATION and stay away from both Butternut and Hustler contraptions, then 43 ft verticals got thrown into the mix because I have read your bias-ness against them on different threads before.
Maybe you can move these posts over to that thread where it is more inline with this subject.
when in fact it may work well on 80 and likely 40m
