I realize this is an older thread but figured i would ask here rather then starting a new 2980 posting. ThxI came across this in my 2980 when trying to drop the low power carrier which will not adjust using the low power vr16 (does nothing). The board in this base is ept360014b. I have checked the voltage going to the main board and shows approx 14vdc. I also found a disconnected black wire floating around in behind the rf power control knob..for now i have dropped the am carrier power from 15w down to about 4w using vr13. Now when the rf control knob is fully counterclockwise its at 4w and when rotated fully clockwise is about 7w am dk
Thanks Nomad. This would explain the crazy gain on the radio and why the rf gain control is needed to be barely turned for all kinds of receive signals.It appears to be R66, in line with the emitter circuit of TR17, the first antenna-amp stage of the receiver. This jumper should have the effect of boosting the receiver's RF gain, and its tendency to overload on strong signals, both.
When it's aligned properly, this radio is more than sensitive enough without this trick. Could be there is another fault in the radio reducing receiver performance, and someone tried to compensate this way rather than fix the actual problem.
Maybe. Maybe not.
Don't thank me. I found an old (May 1st, 2015) discussion on Copper Forum. I typed in; "How to set the dead-key on RCI-2980. It worked for me on my 2980".Thanks Recon. I couldnt locate vr18 on my board and then came across info saying 2980 is same or similar as a DX11B so went with that. https://web.archive.org/web/2016102...s.com/radios/galaxy/dx11b/dx11b_trans_adj.htm
Very confusing trying to find accurate info on 2980. My rci 2980 had board ept360014b.
I am fairly certain my radio doesn't have a vr directly behind the rf power control (maybe this is only on very first 2980s).
I would like to know how many connections there should be on the rf power control as maybe mine has been changed or a wire cut off the rf control potentiometer.
Cheers and thx for your reply.
I am fairly certain my radio doesn't have a vr directly behind the rf power control (maybe this is only on very first 2980s).Very confusing trying to find accurate info on 2980. My rci 2980 had board ept360014b.
I have a 2980 WXThanks Recon. I couldnt locate vr18 on my board and then came across info saying 2980 is same or similar as a DX11B so went with that. https://web.archive.org/web/2016102...s.com/radios/galaxy/dx11b/dx11b_trans_adj.htm
LO power adjustment for the non WX 2980 is on the switch board in front of the power supply. Should be on the right hand corner of that switch board (board that has the RB, Echo, NB/ANL, etc switches). VR803.
Note:
The low power is also affected by the high power adjustment. So, adjust the high power first, then adjust the low power adjustment. Low power adjustment doesn't affect high power though.
Adjust power adjustment as follows:
Use an external watt meter.
1. Turn RF Power knob all the way up (clockwise).
2. Turn mic gain up to normal use setting.
3. Key radio.
4. Say "auuuuu" in the mic and notice peak swing.
5. Divide that peak swing by 4.
6. Set the high power adjustment to the end result of step 5.
Example: peak swing = 32w
32 ÷ 4 = 8
Set high power adjustment to 8w deadkey.
That's a 4:1 ratio.
7. Turn RF Power knob all the way down (counter clockwise).
8. Adjust LO power adjustment (located on right hand corner of switch board VR803) to 1w.
9. Put cover back on and leave it be.
Best way to set the high power adjustment is by using a volt meter for a reading of 5.45v up to 5.65v. That's how I always do it, but you can use the above steps to do it with no problems.
Hope that helps...
That helps allot Hawkeye with mine being plain 2980. Any idea what vr16 is used for on this board ?LO power adjustment for the non WX 2980 is on the switch board in front of the power supply. Should be on the right hand corner of that switch board (board that has the RB, Echo, NB/ANL, etc switches). VR803.
Note:
3. Key radio.
32 ÷ 4 = 8
That's a 4:1 ratio.
Hope that helps...
