Sonar do some more research before you purchase an 811H, better amps available out there for a few more $$$. Just some friendly advice.
I know I should do a search and if I must I will but I find explaining my ex stream lack of knowledge makes people like yourself lay it out in a way i might understand.I do notice the plate tune cap is fully un meshed in the last 2 pics. If it peaks out that way the thing needs some work.
Please exsplain"mesh cap is fully unmeshed" and what are the possible causes and fixes?
the 6 tubes with the darker caps are the SUPER DUTY 6lq6 that are rare, and expensive as fuck.
your tune knob is fully unmeshed, the plate are rotated 100% out of the bottom plates.
That means you are not tuned and will cook the tubes.
What you have to do is with the box unplugged and the capacitors discharged by grounding the tube cap to ground with an insulated screwdriver (to a nearby rivet), is spread the coil that goes from load to tune.
stick a big flat tip in the coils and spead each one 1/16 of an inch.
then fire the amp back up, have a coffee and then tune it up.
Take note of where the tune plates now are after tune up. If they are a 1/4 to 1/3 ways "meshed" you are good to go. If its like a tiny bit meshed, power down, discharge and spread a 1/16" more and try again till its right.
When this in complete you should see a power increase for sure and when you are done and its finally tuning right, dont forget to overcouple the load (clockwise!), till the watts drop down about 50W and you will see the most PEP that way.
UNMESHED!!!
MESHED!!
1/4 MESHED!!
Excellent!! I'm not 100% sure of the coil your speaking of although I've an idea.the 6 tubes with the darker caps are the SUPER DUTY 6lq6 that are rare, and expensive as fuck.
UNMESHED!!!
MESHED!!
1/4 MESHED!!
I'm hoping that since the coil is original to the amp modifying it in any way won't be necessary. Thanks for responding. If there's anything you'd like to add please do. The more educated answers can only help me get edumacated. 73357 covered it, unmeshed is the capacitor set at minimum and full mesh would be it set to max. Sometimes squeezing or spreading the tank coil will fix it it other times you'll have to remove or add a turn from the coil. There could be other things going on too so I'm not telling you you need to do any of this.
I actually miss wrote. The 200 watt dk is before I over couple. It actually winds up showing 100 dk and 600 pep after over coupling.Just some food for thought Sonar. It won't make a big difference, but might want to cut the amp carrier of 200 watts back to about 150 watts if possible. Gives you a better 1:4 ratio.
I think the tube in the lower right corner of the photo near the tuning cap is your bad tube.I've removed the replacement tubes and reinstalled the original d&a's. I'm happy to report that after inspecting everything on the top and bottom side of the amp nothing was fried. The flash that occurred was aperantly one of the replacement tubes.
