Yeah no worries, I bought the scope for shits and giggles and to learn something new... I have no problems using it for target practise. Maybe your right, I should stick to my day job instead of geeking out on a scope.I'm beginning to think you should have bought some knitting needles and yarn instead of a scope. Sorry but I have offered all I can. It is a simple solution I know it and I am sure that if I was hands on there it would be solved in a few minutes with a few simple hands-on tests that I have done numerous times. There is definitely an issue with the grounds in your set up. Someone with a good knowledge of electrical principals should be able to find and solve the problem in short order be-it no ground or reversed neutral/hot leads. Time to call an electrician and let someone who knows what they are doing look at it for you. I don't want to be known as the guy that gave you info that resulted in your electrocuting yourself because you didn't know what you were doing. In the meantime I wouldn't use that scope. It's not junk it simply is incompatible with whatever you have for AC distribution in your home.
Yeah I learned a lot throughout this saga. Thanks to everyone for their input! I'm just a dumb ass oil rigger with a new cb radio hobby.Also the video that BBB posted should help you understand a lot more about what you are dealing with!!! Watch it until it makes 110% sense!!
I object to that statement!!!!!Yeah I learned a lot throughout this saga. Thanks to everyone for their input! I'm just a dumb ass oil rigger with a new cb radio hobby.
Right on! That must have been some primitive equipment to wire line back in 70s. Lol yeah nothing like working up in the derricks for weeks on end.... gets pretty lonely. But I haven't decided what I'm going to do with the scope yet, I'm just going to forget about it for a few days. That would be cool though if you could give me some pointers at a later date, I'd really appreciate it. Thanks!I object to that statement!!!!!
Dude put your feelings of inadequacy aside and continue learning.
I used to work the oil patch back in the mid 70's. I worked for (At the time #1 wire logger service) as an engineer for the well logging service.
I worked for six weeks as an "Attic Rat" on a triple stand rig in South Texas and I didn't know a single thing about the oil patch. If you would like I could give you my phone number and talk you through some test. First: "Do not shoot the scope" this usually turns a good piece of equipment to a boat anchor.
I worked mostly land based logging but from time to time had to log wells offshore. Yup it was primitive gear all right. We had an analog computer and the logging results were recorded on 12" wide KODAK black and white film. Some of the logs films were over 20 feet long. Those films were laid over the top of yellow paper and developed over UV light and ammonia based vapors. Just like the blue line prints for engineering and architectural drawings. I did that that work for five years until the oil field bust.Right on! That must have been some primitive equipment to wire line back in 70s. Lol yeah nothing like working up in the derricks for weeks on end.... gets pretty lonely. But I haven't decided what I'm going to do with the scope yet, I'm just going to forget about it for a few days. That would be cool though if you could give me some pointers at a later date, I'd really appreciate it. Thanks!
Center conductor thru a resistor to ground?!?They say a picture paints a thousand words so here's one I knocked up and use. My home brew RF sampler is made from nothing more than a few resistors and a few antenna sockets. The 2.2kOhm resistor I robbed from an old PSU, the other two resistors are just 100 Ohm 0.25W ones. It gives me -39dB of attenuation out of the BNC connector so I can use it on both my spectrum analyser and oscilloscope with up to a 1KW transmitter. Varying the 2.2kOhm resistor will vary the attenuation you get and there's no need to use a 5 watt one like I have, its just that you really want one rated at least 1 watt and I only had 0.25W ones other than this - remember there's not really much current flowing through it at all even when you're using a 1kW transmitter, its mostly performing a voltage dropping function. The two 100 Ohm resistors in parallel are to ensure that there is a 50 Ohm impedance on the BNC socket. Only downside is because of the type of resistor I used its only consistent for HF/6m because the resistors start to have lower impedance as the frequency increases so by the time you get to 145MHz its dropped to 35dB and by the time you're at 433MHz its down to -30dB.
Hey Rob, I heard you might know where the tuning locations are on a galaxy dx 99v2. Is it the same as the 98hp? ThanksCenter conductor thru a resistor to ground?!?
NOT good!!!!!
That is a load.
Never mind; got a better look at the picture.
Have worked on several 99's and 88's; but never worked on a 98 or a 99v2.Hey Rob, I heard you might know where the tuning locations are on a galaxy dx 99v2. Is it the same as the 98hp? Thanks
M0G -
Just a question: why do you need a 50 ohm impedance on the BNC connector ?? A 'scope or a spec analyzer do not need to look into a 50 ohm load ... or do they ?? To me this setup will just attenuate the signal more, because it is actually a voltage divider.
- 399
