Dont know if he was really good or not but i have a feeling he will vanish soon and take everybodies money i get that feeling is coming soon but i could be wrong.
Andy, thank you for the enlightening insight!The 148-F I had I wrote an article about - way back when on the rec.radio.cb Newsgroup. Hope it's still out there under My Malaria - Cobra 148 - F
The problem lies in the selection of the dropping resistor and choke I call L9 but it can be L501 or a true instance L9 - but it is the power feed to the MB8719, which became the RCI 8719 afterwards. Instead of a 10 ohm and ferrite bead, they used a 100 ohm with the ferrite! Theres the problem - too much power lost and regulator on board can't keep up...WARBLE
The 2nd biggest problem was load regulation and losses thru using the power supply choke and filter for the ENTIRE radio - which made the power choke the biggest culprit and power dropper in the redesign RCI took to.
So he does have the urban legend to live up to but they've solved that problem years ago...
The video is easier to watch if you don't take it full screen. Just leave the video in it's little box.![]()
