i say "lose bias" but a more correct wording would have been "bias changes".
when you bias an amp you both lower efficiency and create extra heat.
heat changes tolerances.
tolerance changes cause voltage changes to the bias circuit.
most biasing circuits aren't regulated and as amp pulls harder, voltage drops causing a decrease in bias voltage.
and one thing that always makes me wonder... as far as i know and what i have always understood. the number "1" in ab1 makes the class ab refer to tubes not transistors.
"1" indicates that the tube draws zero grid current.
"2" indicates that the output stage grid voltage is being pushed above the 0 volt mark and into a positive grid voltage, causing the grid to draw some current from the driver stage.
so are texas stars biased to cutoff?
my understanding is that texas star amps are ab class
class A conducts current 100% of the time
class B has bias point to roughly 50% conducting, this was the old "push-pull" where two stages were used. one stage conducted the 1st half of the waveform and the second stage picked up just as the first was turning off.
class AB is somewhere between class A and class B.
where is up to the imagination... 30-40mils? 70-80 mils? a 2sc2879 calls for 100mils of bias current but you could go as far as 200mils per device as long as you don't overdrive.
so class AB has a "small amount" of bias current is flowing. In the push/pull output stage, there is a little overlapping conduction of each stage.
