I redid the models using a mast that runs to the ground to show the differences it would make in relation to the models above. This is just one possible case for these antennas, and is only intended to explore some of the possible differences between these antenna designs.
Here we see the differences in feedpoint impedances. Both R and X changed more in the end fed design than in the Big Hair design. The change in reactance (X) in the end fed design was especially significant. Because of this it is much easier to design an efficient matching network that will function consistently for the Big Hair antenna than the end fed design.
Here we see fewer currents flowing in the simulated mast in the Big Hair design over the end fed design, although not much. This was expected and predicted above.
Here we see a slight improvement in gain for the Big Hair design over its equivalent with no mast, while the end fed design shows a loss. The difference between the two in this case is only 0.58 dB, which is not enough be noticed in the real world. Any change in the angle of maximum radiation is also minimal in this case.
The DB
The DB
