I can definitely confirm the 60+ output readings. I've been seeing right around 63-65 on the production units that I've tested.
For the doubters among you, I'll describe my test setup for power tests. The radio goes through my
wavenode module, then directly into a
Bird 4314B. The Wavenode module has an RF voltage divider tap, with its output connected to my frequency-counter and o'scope. From the Bird, it goes through a coax switch, then to a 50-ohm resistive load. My test voltage is 14.1 volts, constantly monitored by my bench computer.
My test procedure is as follows:
1. Modulate the radio, setting the vertical calibration of the o'scope so that max peaks (full AM envelope voltage) just hit 8 divisions.
2. Take a carrier reading from the Bird in PEP mode, and take a division count from the o'scope while keyed (NO modulation)
3. Plug the carrier value and keyed division count into a
PEP calculator program which gives a PEP value based directly on the Bird reading.
Since the carrier (CW) accuracy of the Bird 43 series of meters is rated at 5% of full scale, and the PEP is rated at 8% of full scale, I choose to base my PEP tests on the higher accuracy of the carrier reading. Since the scope shows a perfectly proportional relative voltage, it is ideal for calculating PEP at the same 5% accuracy level as the Bird's carrier readings.
Ohms law is the formula, and the derivation is pretty simple.
1. Calculate the voltage being developed at the given carrier level, using the formula 'V = the square root of (P*R)'
2. Take the voltage reading, and divide it by the division count seen when keyed. This gives the actual voltage value of each 'scope division.
3. Take that result, and multiply it by 8 (the number of divisions when modulated) to get the voltage when modulated, then apply the formula 'P = (V squared)/R' to get the PEP level.
With radios using a carrier-control POT (galaxy, connex, etc), it becomes painfully simple to calculate the PEP. Simply set the scope for 8 divisions modulated, then set the carrier control POT for exactly 4 divisions keyed, and multiply the carrier reading by 4 to get the PEP level.
Here's an image which shows the various relationships of ohm's law, so you can follow along.
