Stryker sr94hpc
Ok, did some looking around.
Notice the SMD Op am chip with 2904 on it - just under the connector and by the cut wire?
The 2904 is a similar op amp chip to the 4558 - means it has an op amp for mic and the other for TX/RX switching.
There is another further over to the center by and behind J5 - a 10-pin ribbon cable connector - that connector is by a 2 channel Volume control (Conditioner) for Serial Data...M62429.
Ok, the YD 1517 is a 22 watt dual channel power amplifier...
All the datasheets I could get are on board this post...
The following is based upon observation and may or may not be the proper procedure, it is STRONGLY recommended that you review this post first and then decide - either to wait for verification or if you have nothing to lose - proceed with caution - any and all errors and liabilities are now on you.
Ok, review the above, you can always set up a test jig on a set of test probes with the 470 ohm resistor and see if this works, but the part he's seems to be talking about is here...the yellow box.
The Red box is so you don't get lost. These are steering and power protection diodes for areas that can be exposed to reverse or excessive voltages - they prevent reverse polarity or backfeeding from excessive voltage that can return into a circuit and damage it.
Let me know how it goes...
Andy had the correct transistor circled in yellow. From this view, the pin in question is the bottom left. It already has what looks like a "202" resistor soldered from this pin to ground right below the transistor. Parallel another 470 ohm resistor from that pin to ground. The screw in the corner is an easy place to pick a ground up. The audio will jump to life with the full 40 plus watts of PEP. Anything from 470 ohms to 1k works good here. If the value is too low you may start to hear "pumping action" from the AMC. That symptom would be heard as a sudden reduction in mic gain on the first loud sound the mic picks up. At 470 ohms and with too much mic gain, this can be noticed. The 1k resistor eliminates that but has less AMC range.
Nothing with the mic gain or pre-amp stage can get this radio to talk well before the aggressive AMC circuit is modified to provide a decent adjustment range. Otherwise you just get more background noise with no higher audio peaks. The stock mic is a little lacking in tone quality but the use of the Motorola microphone pre-amp makes the rig sound great. That pre-amp has been discussed here and has been built right into the stock mic with no battery needed. That pre-amp helps with the tone because it breaks the DC line to the mic and inserts an appropriate value coupling cap in series. It also has enough gain to compensate for the loss in the added cap.
KEWL!
UPDATED!
-Realize folks that the SMD transistor pinout are not always "standard"...so some care had to be taken...to preserve the radio...
Reactions: Eldorado828
You're quite welcome.
"Facial Recognition Software" has got nothing on you. (n)(n)
Would love to give you a tour of the place but Wife won't hear of it - so I have to respect that (Mom issues)
But I will keep your post close to the heart - keep your self safe man.
Andy, you're like MacGyver! Sometimes I have to read your teachings over a few times because I get lost trying to process it. Time and time again I see you schooling us bro. You could easily say to us as my uncle once said to me when I'd think I had it all figured out but didn't "remember I taught you everything you know, but not everything I know"
Naw man, I learned all this by helping you guys.
I had questions too!
So why not share in all the fun I had digging this up and putting it together in a way it's "digestible" (Readers Digest - anyone? LOL)
No, I can't take the credit man, this stuff is fun to learn about.
It's folks like you that bring this radio to the table and we can all just kinda' sit around that table and talk about it - each person sees it in a different way and everyone learns by doing - so I learned a lot.
I have you guys to thank for this.
Most modulation limiters prevent distortion. However, the one in the SR-94HPC simply prevents good performance. After reading people rave about this radio "having the strong AM audio Stryker is known for", I bought one. What a disappointment. It has the strongest modulation limiter is more like it.
This lack of strong modulation was not acceptable so I looked around for a schematic to no avail. When that didn't work I pulled the board and tried tracing the circuit from the mic input looking for the attenuation transistor. This board may be three layers because lots of traces disappear from the top of the board to the bottom. Like connections must be happening in the middle.
When that failed, out came the scope to trace the audio from transistor to transistor. Luckily, the desired one is on the top of the board. On the extreme front edge of of the board to the right of the white ribbon cable is a transistor. Two legs face the front edge of the board while one faces the rear. It's the leg on the right front edge of the board we are concerned with.
Solder a 470 ohm resistor to the pin on the bottom, right side of the transistor and ground the other side of the resistor. You could use the screw in the right front corner of the board to ground this side of the resistor. This loads the drive triggering the transistor to conduct and was the safest way I could find to increase the range of both AMC controls without defeating the AMC. It will distort if defeated.
Now the radio screams like 45 watts PEP should. Plenty of range on the controls so they can be set on the scope without distortion. If someone wants to post a detailed picture of this area of the board, I'll point out the location of this transistor a bit better. You should remove the ribbon cable and front panel when installing this resistor otherwise the soldering iron may burn both.
Thanks to you Shockwave, I showed your post and my post to the techs at Stryker and they were nice enough to try the mod out on the sr94hpc themselves with success. Then I did the mod with excellent results. Good job man. Now this radio screams like it should. 45 plus watts just like you said.
You had better luck with any Tech at Stryker than I did. They were very resistant about providing the slightest bit of info on this radio. Not even a schematic. Insisting that I should not attempt any mod of their AMC. The conversation shut right down when I pointed out how the radio was falsely advertised as having a noise blanker when it only has a mislabeled ANL too. Needless to say without their help it only took removing the board 6 times to trace the signal path down to that one limiting transistor. The results are worth it.
  • @ W4KVW:
