Full power output on keydown was/is the original problem on AM; SSB works fine.
2SB754/AM:
RX/base 13.31v
TX/base 12.32v
Robb -
Is the base voltage above measured in AM or SSB mode. 12.3 is ok in SSb, but the voltage should be lower in AM, to reduce the SB754's collector voltage to about 5v in AM. If the base and collector voltages don't change in AM and SSB Check the base of TR52. It should be Low-AM, High-SSB. If these voltages are correct, but TR51 base voltage doesn't change, something is wrong around TR52 or R243. Probably a bad TR52.
