the KIA is a makers mark, its for the Korean Electronics Corporation if i recall, MB is Fujitsu, MC & MM is Motorola, NJM is Japan Radio Co, the 324 is the device number,
here's a link to some of the makers datasheets on cb tricks:
Datasheet NJM324D
a link to many of the manufacturers prefixs:
Manufacturers Part Number Prefix for Integrated Circuit Company
might help you source parts/equivalents.
some general ic info:
IC's
Thanks Jazz. I did buy four of these op amps. They are a very generic, common, and cheap. Paid 60 cents apiece for them. An LM324 made by ST Micro. Popped one in.
Robb -
What is the problem with the metering circuit??
BTW what happened to this radio that it has so many problems ??
- 399
The metering circuit in the SS 3900 uses a 1N4148 diode in the chain that isn't sensitive enough to keep the meter linear and accurate. I put in a 1N60P that has a turn-on voltage that is half of what the 1N4148 will work at (.27v vs .58v - respectively). This makes the meter far more responsive. Could and might pop in a 1N6263 as an experiment; since this Schottky is even more sensitive than the germanium/1N60P is. Meter works fine now in all modes; but I will experiment to learn.
How to wake up a lazy S-needle on SUPER STAR 3900 (EPT3600) - YouTube
Also put two 1N6263's in the NB and receive circuit too.
Also replaced the TR41/2SA473 voltage regulator for a TIP42 that has better specs. It is an upgrade. Bought four of these also, as they were also 60 cents apiece. Gonna put one in my Galaxy DX 99V too.
Also plan to replace the two 1000uf/25v electrolytic caps, and perhaps even the 2SB754 for a 2SB817.
Replacing D86 & 87 got the RF meter to read and adjust better on TX.
Replaced the meter/lamp too.
Radio has come a long way already. The channel display LED is going to get checked out next, as the first digit doesn't work. Registers '1' and '4' OK; but not '2' and '3'. Hopefully, it is just a bad solder joint or a short. But if it is bad, I have another to replace it.
Added a talkback switch by lifting one end of D80.
What happened to this radio? Think it was well used/bit worn out. It was hacked as well; the TR32 was pulled out and so was R249. Just abused and used up. But it has come around nicely. Checked the modulation wave forms on SSB and AM on the scope last night; they both look OK now.
