I have been googling images of the Trombone match used in the i10k to see how it works ... now have i got it correct ? as i see it comparing it to the maco/sigma 2 typ ring which has 1 end to radals the other end of the ring to the radiator and the feed line is movable on the ring till a match is found..
with the trombone the feed looks if it is fixed, and by sliding the trombone this appears to have the same effect as making the ring on the maco bigger or smaller instead, but ending up with the same result ....is this correct or is there more going on with the trombone........
Dave
Dave
