I'm siding with you on this...
Three that's 3! different SWR meters. Two ordinary ones plus a radios' internal one. So something in the process of elimination - isn't right...
Again linearity of scale - if they can't make the meter work right on low-power - how is it going to handle low level ORP rigs' using Fleapower?
Ya' gotta' blow that 10-ohm smoke into it?
No! Two "simpleton" low-power meters show differently and both acquire similar results as SWR is fine - only thing that messes this up was from the improper power ratings - and when we do put in a meter rated for that power - it can't register the radios' low-level power - SIGH...
Oh this is bad, and sad...understandably questionable... But! If you have not changed anything except the meter, you're fine. The SWR the system says you have, via two meters, is ok as far as low power to even higher levels within the ratings of the individual meters - so judging by scale of events - MFJ is simply not able to produce ACCURATE readings from the low-power levels the radio has, and requires to produce, in order to make his system work.
I've been there - done that - and with 2 out of 3 - it ain't bad!
I've gone into brand new meters to verify the case to coax shield (the outer ring of the SO-239 and PL259 shield) - is tightened so there are no doubts about case to shield contacts. I've had meters with poor assembly problems before and radios with goofy SWR got fixed by an 11/16th wrench on the SO-239 nut to tighten it down to the rear panel...
But this symptom? Means the CONSTRUCTION internally to the MFJ onto the parts used and circuit design for it, is not built for flea-powered QRP rigs...the sensor - detector design as well as the parts used - are simply not set up for this - power can't be properly detected if you have to skew the calibration of the unit to suit the needs (hard over full stop).
Why doesn't the MFJ set??
I'm supposedly at 3+ w with stock radio.
Also the radio has built in SWR meter and thus far has proved accurate in my truck for over a year and also matches the Astatic readings within a .
Also antenna is new A99 that is tuned from factory and I only moved a hair hence the 1.2 I'm getting probably.
I get 1-1 and 1-1.2 across band with out anything inline.. and then with Astatic only inline the same..
