Those two are for you Clarifier/Voice Lock. Orange is the one that goes to R415 - and then to GROUND.
The White Red stripe is the SOURCE from RX side (means that it only has voltage when in RX)- else it DIES on TX - So that board supplied the power and offset trim resistance for the Voice lock pot.. ORANGE is your RETURN wire from Voice Lock back to board and to the offset resistor 3.3K THEN to GROUND.
So they sourced constant from somewhere else - more than likely direct from the Pin 1 of the MB3756. It's in another one of your photos see (Red wire) the foil side...When all they had to do is unsolder White / Red stripe wire and re-source it back to the PLL's own sourcing by L501 - that Ferrite Bead - and relocate R187 across Source ... From L501 - ACROSS - to wiper as pull up offset - everything else could be left alone.
This is a best guess, but you will need to rework R187 - make a decision to restore ORIGINAL condition and keep R187 in place or REMOVE R187 and REINSTALL across SOURCE and WIPER for Voice Lock pot AT THE POT
The board has all the rest of the support parts to RECENTER your Voice Lock pot if it still has one - that 3.3K is the offset trim resistor to force the pot to slide more towards positive voltage range towards SOURCE.
