I have been resoldering alot of connections since last time. but still no receive. transmit is fine. I checked for a frequency starting at the antenna, and found 16.9204 on pin 4 ,of /L2 or, a15 i checked the fequency from the channel crystals. it is correct 8.460 m17 at pin 2 v2.but when i checked The 9.979mhz crystal. it is 9.976on the fine tune side and 16.9204 on the other side going to pin 1 of v4 . i measured the resistance of the 22k. resister it is over 24k . above is the schematics. i noticed when i put a 27.125mhz signal thu the antenna to pin 12 in the relay, it comes out at pin 4 at 16.9204. im confused.
