i'm planning a beach trip during the next couple weeks.....been setting around think up antennas to take and setup as a portable DX antenna. The antenna must very portable (due to size) and the mast can be no more than 20feet. My plan is to take a 102 whips and a couple 10 foot fence top rails to use as a mast, some wire to use as radials(if needed).
thought about taking two 102 whips and making a hor. 1/4 wave dipole that can be rotated? or may just use the 102 on top as a vertical. I think the take off angle would be better for the vertical for DX as all the mast we can take is 20 feet of top rail....what do you guys think would be the better antenna with these limitations?? My question about grounding is, if the grounded end of the mast (top rails ) are buried into the sand a foot or so(wet sand) to stablize the base,(using rope as guys) will i need to run a ground wire from the 102 whip down the mast and attach to a ground rod or will the mast act as my ground?
second question is can anyone tell me the take off angle on such an antenna?
setup will be on the sand, at the beach feet from the gulf of mexico around 60 miles south of corpus christi tx
i'll post before we go and see if any members can make contacts the plan to work the station for 3 days.
