So I've been hunting a power supply for my galaxy dx98vhp which by the manufacturers specs has 10-50w am 200w usb/lsb current drain 25 amps am 40amps ssb and takes 13.8v input voltage
With the given formula
watts÷volts=amps
Am I assuming correctly that I only need
At minimum a 15a power supply to run this one radio
Or that would mean the radio would put out 552w doing the inverse amps X volts = watts or do i need to get a 50 amp power supply just wonder if im using this formula right or if it applies so something different
watts÷volts=amps
