The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
that was my choice as well. from what i have seen the 5000 appears to be finicky for some reason, totally different from the 1000.
if i had that mfj antenna analizer i would have tried to change the design. it seems to work ok as it is, but nothing to write home about.
being that their are those that have said that they have had no issues with them leads me to beleive that the Quality control issue is the heart of the problem with these antennae.
Just found this thread, I didn't know that the coil would come apart. Mine had water in it until I drilled a few holes in the bottom. Now I am tempted to take it apart.
Yes they are good for doing that. I know the OP and we talked about this very problems years ago. I was seeing it a lot with the 1000’s though, rarely an issue with the Trucker style antennas and I personally never saw it on a 5000.
That coil will sometimes break loose from the ends it’s attached to. Take it off the mag base and check it for continuity and you’ll know if it’s broken or not. Hitting tree limbs seems to be the #1 cause, naturally.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
