Hey guys, I need some advice. I have been running my X-Force 600HD with my Stryker 955 for about a year now. The other day I was talking on it on side band and noticed the output power disappeared. I unkeyed real quick and went over to the amp shelf and smelled an electrical smell. I unplugged it and popped the cover off. The smell seemed to be one of the transistors. Also the resistor on the output combiner is toasted. One of the output transformers was still warm, the transformer on the side with the smelly transistor was cold. Like that side wasn't making power.
The SWR when it was in operation was under 1.5 and the Power Max 100 is set at 14.5v. When on AM, the radio was set to a 5w dead key swinging up to about 60w. This gave an output of about 150w dk swinging up to about 600w. This is pep watts on my Autek WM-1. I suspect that the transistors were not well matched to begin with and when the one went out, it took out the balance resistor?
Can I just put in a matched set of transistors and replace the resistor? Or are there other things I should be checking first? Any and all comments welcome.
