[QUI no i'm not. I'm Roman Catholic. TE="crappykraco, post: 499130, member: 42325"]You really are a moron.[/QUOTE]
No I
No I
100W into a Moxon beam even at 20ft will get you all the way around the world this time of year.
Thanks captain. Audio shockwaves set me straight on that . What I really wanted to request in my first post was an amp.that peaked at 400- 900 but instead of correcting my question I let it stand so that I could gain knowledge about why that wasn't feasible. Just like audio shockwave, you to a wwdx friend who's advice and posts I often read in order to lean. I know when it's posted by you it can be taken to the bank. as a matter of fact when I ask a question I'm always hopping that many will answer but, am always glad when shockwaves or yourself whaight in. Thanks. Thanks for everything.900 watts of AM carrier would require about 3600 watts of peak power in order to be operated properly. NOT a small requirement at all.
I would say I would do the following:
1. Replace the A-99 with an alum antenna (I have never had good luck with power and A-99s)
2. Buy a HF amp like the ALS-600 that runs off of its own power supply (48 volts) review here http://www.eham.net/reviews/detail/603
3. if you can go higher then go higher, if not then so be it/
ThI would say I would do the following:
