[QUUTE="wavrider, post: 499139, member: 9893"]So YOUR A99 is 8' off the ground?
You want an amplifier ( splatter box) that will dead key 900 watts?
Then if you operate your station like you install an antenna the amplifier will swing backwards???
Do your neighbors and yourself a favor, operate mobile with that 900 watt splatter box you want.
With your antenna at 8' to the feed point you will be the source of so much tvi and rfi.
OR MAYBE JUST MAYBE take the time to educate yourself and what a radio station REALLY is and find out what is the single most important part of your radio station.
IT IS THE ANTENNA!!!!!!!!!!!
It transmits your signal and also receives.
YES YOU can talk "SKIP" off of a wet noodle right now, nothing to do with an antenna it is a solar cycle.
Something you can google and study so YOU understand why your A99 at 8, is talking to Europe without an ROTOR.
YOU my 11 meter wanna be splatter box operator friend have a lot to learn.
Start with some standard operating principles. then Study antenna theory.
THEN decide if you need an amplifier.
http://www.hamuniverse.com/linearamp.html
READ the above article, it is all FACTS not hearsay.
Many have posted here giving sound advice and you have replied with off color remarks and straight out being rude, IMO.
If you going to ask a question that you really want an answer to based on sound operating procedures and REAL theory then be prepared for the answer.[/QUOTE]
Over come or reach a compromise with hoa on tower and antenna installs.
Just a few suggestions
Very rarely does increasing power output help unless it is 75 or 160 meters where noise is s9 plus normally
I'M SORRY TO REPORT THAT STELLAS STILL A RAT HSS BROKEN HIS LEG AND HAD TO BE SHOT! PLEASE FORWARD ALL RESPONSES TO GREEN LAWN CEMETERY BROOKLYN NY. THANKS. DONNA, COMMON LAW WIFE. P.S. IF ANY BODY IS INTERESTED IN PLENTY OF RADIO EQUIPMENT PLEASE MESSAGE ME ON HIS WWDX PAGE IN CARE OF DONNA DOYOUWANNA. THANK YOU
