Good choice on the GPS and speaker mic, but it's also a must for the high capacity battery and if you can afford it the drop in charger. You'll regret not having the high capacity battery when using the speaker mic and gps, plus the drop in charger will keep you up and running when you need to change batteries. Having to tie up the radio to charge the battery is a real drag.
