Crossband repeat timeout
NE4W
Feb 14, 2011
2
Do all current dual band rigs include a transmitter timeout while in CBR mode? I was hoping to use CBR (at the lowest power level) around the house for the weekly net, but our repeater seldom drops completely during nets which means that CBR would timeout before the net completes.
it might help if you would say which radios you're using that don't have a time out timer while in crossband repeat.
My kenwood TM-V7 does have a TOT in CBR mode set at 3 min.
My Yaesu FT-8900 does not have a TOT in CBR and has been keyed up for well over an hour at 5-10 watts with minimal heat on the heat sink.
My kenwood TM-V7 does have a TOT in CBR mode set at 3 min....
the TM-v7 does have a tot default setting of 10 min. (also adjustable for 3 & 5 min.)
but,...... the tot has nothing to do with the CBR function, it also functions in the simplex and repeater modes.
the TOT does have to do with the CBR function because with the TM-V7 the tot is set to 3min while in CBR mode and it is not adjustable. Sure the TOT can be adjusted to 3,5,10min while in normal tx mode it is not adjustable in crossband repeater mode.
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
