RatsoW8
Supporting Member, W9WDX ARC Member - WD8T
The SWR is fine with the amp inline and off with either the meter before or after it. I only have the issue with the amp on. The meter I am using seems to be acting weird it reads a little higher than my other two and it never reads flat on any frequency like the other two but has a higher wattage rating either with or without the amp inline or on or off.
T23
Ok. Now find 200W dummy load and do the same test. No dummy load, then here's what I'd do. Not necessarily in this order.
-replace the feedline with RG-8X.
-rework all the PL-259's in the system.
-Make sure you have a good connection at the antenna.
-If the antenna wire is bare copper it it touching anything or very close to any object?
