Forum HF contest 16-17 May.
That freq is do able, top of the band, my VSWR is a little high there as I am cut for the bottom but the tuner will take care of that problem.
Working straight through until the 21st:(
Will try to get on the bands after work and early mornings.
Reactions: binrat
4x multiplier for QRP. For this contest QRP is 10 watts or less.
The above will qualify for any contacts made with me. I have a power amp but I don't run it because the neighbors all have old equipment and my transmissions cause them to freak out a bit. Plus the wife is on vacation and she is keeping me busy running and visiting and doing all of the things she doesn't have time for during the work week.
I will be on and off the air so it will be catch as catch can.
Reactions: binrat
Does anybody have a template for putting the contact information in a format that can just be copy/pasted in to the contest data? That would eliminate extra key punching.
I am lucky to get just a few contacts in the last couple of contacts. Sure did not take much time to put the contacts on the forum.
Word or notepad can be copied and pasted.
Okay, I understand. I was hoping for a spreadsheet format with the columns named for "Call Sign", "UTC time", "Signal Strength" and "Frequency". If there was a standard format it would be very easy for the judges to just import the data.
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
