The Search for the Perfect Antenna . . .
I didn't want to drill another hole in my wall of my house.
Probably won't.
I was referring to the panel outside. There is a ground bus bar that wires can be attached to. Usually many open spaces, takes a flat head usually. Knock outs on the box allow additional access. You can add conduit if you are anal or just run the wire out to a rod with a ground lug. You may have one already. Check for corrosion if existing is present. You could facilitate the existing ground wire from elect outlet by adding a jumper out to ground lug on unit.
You need more impedance, and more Advil
Am already maxed out on Aleve for my achin' back.
Another problem has presented itself and a google search revealed NSAID medications like Aleve, Advil and Motrin often cause constipation. More impedance is the last thing I need right now. o_O
OMG!!!!:eek: Way too much information there Riverman. But, may I suggest some prunes and coffee?:coffee:
Reactions: Riverman
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
