The Search for the Perfect Antenna . . .
I didn't want to drill another hole in my wall of my house.
Probably won't.
I was referring to the panel outside. There is a ground bus bar that wires can be attached to. Usually many open spaces, takes a flat head usually. Knock outs on the box allow additional access. You can add conduit if you are anal or just run the wire out to a rod with a ground lug. You may have one already. Check for corrosion if existing is present. You could facilitate the existing ground wire from elect outlet by adding a jumper out to ground lug on unit.
You need more impedance, and more Advil
Am already maxed out on Aleve for my achin' back.
Another problem has presented itself and a google search revealed NSAID medications like Aleve, Advil and Motrin often cause constipation. More impedance is the last thing I need right now. o_O
OMG!!!!:eek: Way too much information there Riverman. But, may I suggest some prunes and coffee?:coffee:
Reactions: Riverman
    BLACKOUT HF
    I am beginning the packing process...XENIA bound Going "Lite": this year....2 items for sale...Rig #1 = FT-920/Gud to Ex condition/Hand Mike/pwr cord/manual (NO BOX) ... #2 = My 1 owner FT-950....EX condition...Original Shipping Double Box/Factory Manual/Never used hand mike...Booths 9107-9111...Ya'al come by say hello...
    Incoming Region Produces X3 Solar Flare
    May 15, 2024 @ 14:55 UTC
    Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned
