ClearComm AR3500: need to identify parts for alignment
Roger Dodger
128
15
28
Pennsylvania (west)
Trying to align an AR3500. I have the alignment procedures that lists what to connect to & what to adjust for, however the test points and coils are not labeled on the pcb among other items used as test points. Anyone got a pictorial or diagram labeling what is what? I've traced & identified TP 1, 2, 3 but the IF xformers aren't labeled, and the xistor id # (Q, 1, Q2 etc.) are covered on the pcb by the component itself. Searching online in different forums hasn't been productive either. Thanks.
http://www.cbtricks.com/radios/clear_channel_corp/ar3500/index.htm
Reactions: midnight special
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
