Sams PhotoFacts Collection
Ladies and Gentlemen The Realistic TRC-424 from around 1977ish ...see zip attached below.
View attachment 68472View attachment 68473
I consolidated your Zip into a single modified PDF. As usual I spliced together the schematic, and put it in a separate Jpg file. The high resolution of your original scans were great, but the circuit boards would have turned out a little clearer if they were scanned in at least 256 grayscale or color. When more shades are provided, I can use programs that can fetch out details that you won’t normally see. Overall your addition was well worth saving and I appreciate that post. I always look forward when someone posts a new high resolution scan. There are too many low res scans on the web that was done on equipment made years ago. I can’t tell you how many times I downloaded a needed schematic, only to find out that it’s unusable.
  • TRC-424 service manual.pdf
Thank you Sunbulls. The schematic looks awesome with it spliced together.
I'll take a look around and see what I can upload, as it may help someone down the road.
  • @ nomadradio:
  • @ c316buckeye:
    no conditions in ohio
