2970 N2
This has very little to do with the radio and everything to do with mother nature.
YUP YOU ARE ENTIRELY CORRECT .. I LOOKED AT A NATIONAL RADAR IMAGE ON THE DAY I TALKED TO ATLANTIC CITY AND MONTREAL AND GUESS WHAT ??? THERE WAS A TROUGH OF CLOUD COVER RUNNING FROM THE SOUTHWEST TO THE NORTHEAST.. MAYBE IT HELPED MAYBE NOT BUT I RARELY MAKE MAYBE CONTACTS IN THE NORTHEAST U.S. .. OR PERHAPS DIVINE INTERVENTION ??? XXX
I have a 2970N2 transceiver and it works well. I also have a few larger base variants of the 2950DX chassis. Although the mobile version 2950DX-2970DX doesn't have the classic CB radio look per say, it still has very nice AM modulation that you would expect from RCI/ Ranger products. The SSB is very usable.
The only down side I have encountered with the newer version 2970DX was that the irf520 mosfets in the amp section are sensitive to high VSWR. Two of the (8) popped when I had a coax connector fail open. That happened while running a 10 watt carrier on AM. After I replaced the bad coax jumper and all (8) mosfets it was back to working fine. They are under $2 and from the same production run if you get them from RF Parts. They were selling the entire amp board for like $70 but I see they are not listing now. I did think about swapping in the old style 2 x 2sc2290 amp board from an old 2970 in but the new mosfets I put seem to run just fine.
If you like to run AM mode you will not be disappointed. Stable SSB is just a benefit of the 2950DX chassis for me.
https://www.rfparts.com/irf520.html
got a 2950 and a 2970 n2 .. love em both and I am going for a 2970 n4 ... gotta get a bigger power supply ... the 2970 n2 makes my 50 amp astron grunt I think a n4 will turn it inside out .. the trick to longevity with any of the 29xx boxes is don't run them wide open and they will last a lot longer .. xxx
Im no electrician, but doesn't heat rise? They should have put the amp on the top on those radios.
Reactions: Captain Kilowatt
I don't mind the replies unless they are like this one. I don't need smartass answers. Just the facts will do.....
yup the same ole sh!t !!! get a hf rig. blah blah blah.. woof woof woof .. and so on and so on ..so many friggen radios so little time ...xxx
    63Sprint has left the room.
