Alpha 10 Max AM-1000 Overview
Well Thank You for the explaination but in reality lets just talk about a 40 channel ssb radio from lets say from 1980 compaired to a Galaxy 959. My old Lafayette worked fine from turn on to turn off no matter what the temp give or take 5 minutes, the Galaxy 959 that I had came from the factory off frequency cold or hot, once aligned it would be off for the first 10 or 15 minutes, work ok for about 15 minutes and if I talked a lot would go off frequency the other way, like just say it was high cold , ok warmed up then would go low when hot, none of my old radios do that, they might be just a tick high dead cold then go on and stay there on my usual channel 39 LSB. I do understand we paid 300 or more for those old SSB radios but they worked correctly, these newer mid range price radio work like poop and people still buy them. I have one of those Alpha 10 Max radios, it's dead on from cold to 110 degrees no matter what. Is it newer tech stuff or just the older parts were built with better tolerancees??
Ah, yes, the TRC449. Mine is still rock solid even after 30+ years. Best Uniden chassis ever made, IMHO.
As the cost of manufacturing goes up, the quality goes down. Those early radios were made in Japan, which by then had a mature electronics industry with a reputation for quality. Then the offshore competition came in from... Taiwan, Macao, Malaysia, The Philippines... It just became harder to compete with each newcomer. You have a set price-point and you have to meet it... so you too go "offshore". With each new competing country, you have new start-up rough spots and a learning curve.
That Galaxy 959 is probably made in China. Whats interesting is that for all intents and purposes, China is now a mature electronics industry for the most part. For the most part, most Chinese factories are producing excellent product. Except for the new start-ups, which have a learning curve, as well as competition from the older established factories.
Today, US distributors need to find cheaper and cheaper sources to make the same chassis (and dollars).
The Alpha 10 radios are made in a mature, established facility, using modern SMD technology, and modern uP based PLL circuits. Most of the Magnums, and some others are made in the Goodwill Telecommunications Engineering Co. factory. The Alpha 10 Max and the "AnyTone AT5555" are made in the Qixiang Telecom Co. factory. Both facilities are modern, up-to-date facilities which use SMD technology and uP-based PLL circuits. I believe that the latest Galaxies now are also made in the Goodwill factories. But I suspect that at their price-point, cheaper parts or a cheaper design is now used. Not sure. And definitely not sure why a simple 40-channel SSB radio should drift? I would guess that the factories are cutting back on quality parts, to meet US price-points.
The only thing I can think of is that those radios already come broad-banded to accept "Viagra" boards, etc. Broad-banding contributes to drift, as the circuit "Q" and tolerances are lowered.
Oh, and one more thing... I know for a fact that the quality of the assembly workers in these factories is going down. My own OmegaForce S45HP came out of the factory with the FM discriminator poorly aligned, and the clarifier off set (on frequency = 11:00 position) which means that the frequency alignment was sloppy. This is due to poor training, or a very inexperienced calibration tech. (Luckily, I have the alignment instructions and set it right.) I'm seeing more and more poor alignment in many radios right out of the box.
Hi Ed,
I am not sure but I think you will find galaxies and connex come from a ranger plant somewhere...I don't think from goodwill. 257 and S-45 are philipines
rgds,
Dave
Quite possibly true. I was going from my (notoriously faulty) memory. I think that the Magnum S9 series are made by Goodwill, but I could be wrong. Or just maybe, Goodwill is making "clones" like so many factories have done?
Bruce at DX Radio City has them also and he's down to 269. I found someplace yesterday on the internet that had them for 199 but might have been out of the USA I'll look later to see if I can find it again
Did a mod to my Alpha this weekend, it was listed at their web site, removing one of the smt parts, had to be extra careful because of the small size. The modulation pot is still functioning so it's not like taking out the clipper circuit, the audio did pick up a lot on AM and SSB is still very loud and stable. It's at www. alpha10radio.com go check it out, nice enlarged pics with good directions and they work very well
Anytone at-5000
I've used my Anytone version for almost a year now and it is working fine! Ordered it as a factory sample and it has the RF RAIN on the front.... :oops:
Good reports on the audio with stock mic, a bit light on AM but SSB and FM work well. Mine in very stable on SSB from the get go! The receive is very good with a sad ANL and noise blanker but it works.... :D
Over all it has been a pretty good radio and but for the fact it looks so much like a normal CB, one would think of it as more of an amateur transceiver. :confused:
73 Rod aka mechanic
I have to say Rod aka Mechanic, my Alpha and my Magnum Omega Force are the most stable SSB radios I have every used, the Magnum is very nice has lots of power but I have to say I like the Alpha better because of all the buttons and functions it can do, just a Great all around radio no doubt.
What is meant by white noise on the modern 2950DX SMD boards??? I owned a first and second Gen RCI 2950 and never had white noise on mine? I aligned them every year though which was more a check then a true alignment as they did not get off much over a 12 month period. Is the white noise on transmit or receive? Is it an RF gain issue or a need to use your sq to get rid of noise in the recieve side?
That is how I knew my Voltage regulator had gone bad on my first Gen RCI 2950 the side band started to drift and I talk 99% on SSB. Prior to that my rig was the unofficial "this is dead on center" rig that people would use to tune too. I always upgraded a part when one would fail. Then a few years latter the crystal filter went bad.
Voltage regulators and cap's are often the source of stability issues. A marginal cap can cause noise as can a marginal transistor. For the transistor I mean it is not up to the task handed it and is used for cost reasons. Now that everything is SMD the regular Joe can not use a $30 soldiering iron and easily swap out caps and transistors.
I would have to imagine since the RCI 2950 is 10-12M and is sold to amateurs and other's the white noise issue must have been figured out? Anyone??
